TwinTurbo.NET: Nissan 300ZX forum - It's not hard.
Subject It's not hard.
Posted by BlackholeZ on August 10, 2017 at 10:12 PM
  This message has been viewed 703 times.
In Reply To Steering rack U Joint replacement tips or writeup anywhere? posted by Poom (Pittsburgh) on August 09, 2017 at 08:51 PM
Message Remove both lock bolts on the u-joint completely. Loosen the steering rack mount clamps and rotate the input shaft downward to slip the u-joint off. You might have to tap the u-joint off the steering shaft. Reverse process and it's back together. I don't tighten the u-joint until the I've tightened the steering rack to make sure things aren't loaded.
-Dan
VTC Solenoid Caps href="http://goo.gl/GaK9E">and install instructions.
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" -
ChristopherTheOne
" Purrs like a sexually satisfied black panther." - BigTDogg
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
