TwinTurbo.NET: Nissan 300ZX forum - Check the following
Subject Check the following
Posted by dvice on July 14, 2012 at 10:07 PM
  This message has been viewed 159 times.
In Reply To hesitation posted by GCamp on July 14, 2012 at 07:59 PM
Message - Pull ECU code by turning screw on ECU while ignition is on, search for "300zx pulling ecu codes"
- If code 34, it's possible you mixed up the detonation sensor plugin with another plugin that also fits (can't remember..VTC or O2 sensor or something)
- If no codes, look for boost leaks
- Use the OEM spark plugs and NOT some you can get at your local parts store. Gap them correctly. This is very important.
- TPS/CAS, clean the connectors and check them for proper adjustments
- Since it's a 90, read up on the bottom of this page:
[ http://twinturbo.net/nissan/300zx/FAQ/FAQpages/hesitate2.html ]
More info would be easier to help you. How many miles, when does hesitation occur, etc.
