TwinTurbo.NET: Nissan 300ZX forum - Follow-up: Lagged idle response from idle
Subject Follow-up: Lagged idle response from idle
Posted by Draker (Eugene, OR) on August 09, 2011 at 12:18 PM
  This message has been viewed 162 times.
Message I hoping this will be the last post. After finding the CAS fully clockwise I tore everything down and counted teeth a few times. All the number were correct 59, 24, 45, 24. I put everything back together.
As Woody pointed out I had the ECU timing confused with the ignition timing. So when my timing light matched the ECU timing on ConZult, I thought I was good. This was incorrect. I broke out the timing light again and timed it from the #1 spark plug this time. Now I'm at 15° and steady.
The hesitation from idle seems to be gone and overall power seems better. I think I still have some lingering issues, but the hesitation seems to have been fixed.
#fingerscrossed
Heres a recap:
First Post - La-Z-Link
I just noticed my Z is poor to respond when trying to accelerating quickly from idle. For example, if at a stop light and it turns green and I get on it, it's very sluggish but it doesn't really bog down. It does the same thing if I blip the throttle while in neutral. I also noticed a little bit of an irratic shift or incorrect shift points in the transmission (auto). See below.
A little background, I finished swapping a different TT engine into my car last year. I don't really drive it much. Probably less than 500 miles in the last year. Partially because of the swap. During the swap I did a 60k and set the timing, counted teeth about 3-5 times. I installed a new EFI harnesss. Everything seemed good, it runs fine in the upper RPMS. Idle is fine.
I've checked the TPS and set it per the service manual. It was already set correctly.
I am thinking I will probably put new spark plugs in it. I didn't put new plugs during the 60k because I had them from my old engine with only about 20k on them. They are the correct plugs for a stock Z, which mine is.
I also have a spare MAF I might put on it to see if there is any difference. The MAF I have on it now was sitting around for a while during the swap and I could see element inside collecting a little dirt. Might try cleaning it as well.
I know I set the TPS per the service manual, but I do have a spare to throw at it also.
I did a boost leak test and it seemed fine might be time to do it again. Last time it leaked down at 10sec/lb. OR 50 seconds for 5 lbs and so on.
I've yet to check the fuel pressure, I figured I would swap out a few things here and there. The first thing I thought of was the TPS and it needing adjustment. I know if it's out it can cause the transmission to shift at strange points. But sure enough it was adjusted correctly. I checked for codes in the ECU and TCU, none in either at this point.
The car is stock, have a 95 engine with new style injectors, new style cas.
Please let me know if I might be missing something here. If you have had this issue, what did you do to solve it? I've ran through the 6p's after the swap everything seemed okay. Now, not so much.
Thanks.
Second Post - La-Z-Link
Steps I took:
- Checked if TPS needed adjustment. Found to be @ .46v and no adjustment made.
- Replaced MAF with spare, problem still present.
- Leak checked with smoke machine, none found.
- Boost leak checked, None.
- Pulled TPS to clean, found lower mounting bolt missing. Opened TPS, found to be clean. Reinstalled with 2 mounting bolts. Test drove. Shifting is now accurate, and throttle response has greatly improved from idle.
Third Post - La-Z-Link
Steps I took:
- Replaced pfr5b-11 with brand new ones.
- Purchased blaZt cable and software
- Verified Temp Sensor Reading is good. (@ 170-180°F)
- Monitored O2's. Found one to switch slow, replaced with spare and now both are normal.
- Power Balance test
- Verified Timing set at 15° and steady
- Replaced EGR Temp sensor (Which was hanging in engine bay due to no EGR) with resistor.
Fourth Post - La-Z-Link
- Tightened throttle cable to remove slack
- Verified throttle bodies are synced.
- Found CAS fully clockwise.
