TwinTurbo.NET: Nissan 300ZX forum - Lagged throttle response from idle continued!
Subject Lagged throttle response from idle continued!
Posted by Draker (Eugene, OR) on June 20, 2011 at 1:25 PM
  This message has been viewed 311 times.
Message And right when I thought I was out of the woods...
Heres a recap:
First Post - La-Z-Link
I just noticed my Z is poor to respond when trying to accelerating quickly from idle. For example, if at a stop light and it turns green and I get on it, it's very sluggish but it doesn't really bog down. It does the same thing if I blip the throttle while in neutral. I also noticed a little bit of an irratic shift or incorrect shift points in the transmission (auto). See below.
A little background, I finished swapping a different TT engine into my car last year. I don't really drive it much. Probably less than 500 miles in the last year. Partially because of the swap. During the swap I did a 60k and set the timing, counted teeth about 3-5 times. I installed a new EFI harnesss. Everything seemed good, it runs fine in the upper RPMS. Idle is fine.
I've checked the TPS and set it per the service manual. It was already set correctly.
I am thinking I will probably put new spark plugs in it. I didn't put new plugs during the 60k because I had them from my old engine with only about 20k on them. They are the correct plugs for a stock Z, which mine is.
I also have a spare MAF I might put on it to see if there is any difference. The MAF I have on it now was sitting around for a while during the swap and I could see element inside collecting a little dirt. Might try cleaning it as well.
I know I set the TPS per the service manual, but I do have a spare to throw at it also.
I did a boost leak test and it seemed fine might be time to do it again. Last time it leaked down at 10sec/lb. OR 50 seconds for 5 lbs and so on.
I've yet to check the fuel pressure, I figured I would swap out a few things here and there. The first thing I thought of was the TPS and it needing adjustment. I know if it's out it can cause the transmission to shift at strange points. But sure enough it was adjusted correctly. I checked for codes in the ECU and TCU, none in either at this point.
The car is stock, have a 95 engine with new style injectors, new style cas.
Please let me know if I might be missing something here. If you have had this issue, what did you do to solve it? I've ran through the 6p's after the swap everything seemed okay. Now, not so much.
Thanks.
Second Post - La-Z-Link
Steps I took:
- Checked if TPS needed adjustment. Found to be @ .46v and no adjustment made.
- Replaced MAF with spare, problem still present.
- Leak checked with smoke machine, none found.
- Boost leak checked, None.
- Pulled TPS to clean, found lower mounting bolt missing. Opened TPS, found to be clean. Reinstalled with 2 mounting bolts. Test drove. Shifting is now accurate, and throttle response has greatly improved from idle.
New spark plugs are on the way, and will verify fuel pressure to ensure no underlying issues remain.
Now back to the present. After doing all the work I mentioned above the shifting issues seem to have greatly improved. I thought I had the lagged throttle fixed but it was probably a 'jeti mind trick' to where it felt like it was fixed, but wasn't.
Since my last post this is what I have done.
- Replaced pfr5b-11 with brand new ones.
- Purchased blaZt cable and software.
- Using software found right O2 to be switching slow. Replaced with spare part and now both O2s switching normal.
- Replaced EGR Temp sensor (Which was hanging in engine bay due to no EGR) with resistor.
Also did serveral tests with diagnostic software including power balance, base idle.. No issues. Timing is set at 15° and steady.
Temp sensor reading is good @ 170-180°F.
While monitoring the O2s, I found at idle they would sit at either rich, or lean (Can't remember) and not switch or switch very little. Once any throttle was given they would bounce back and forth all the way up through the range. I was wondering if anyone else might have seen this before? It could be normal behavior.. I will need to spend a bit more time watching them operate.
Maybe what I am experiencing is normal for an autotragic? It doesn't seem like it is though. I can feel and see the RPMS drop slightly right before they start to rise when excellerating from idle. (In neutral or D)
I guess my next step will be to replace the IACV/AAC with another unit. Although from the software, it seems fine.
Your thoughts are welcome.
Thanks.
