TwinTurbo.NET: Nissan 300ZX forum - A new problem now..
Subject A new problem now..
Posted by 300zx_2+2 on July 24, 2011 at 9:48 PM
  This message has been viewed 124 times.
Message So i been searching and searching and swapping out parts and nothing seems to be working for me. Here’s a couple of links from before... [ http://twinturbo.net/nissan/300zx/forums/technical/view/1115519/Warm-start-up-problem.html ] [ http://twinturbo.net/nissan/300zx/forums/technical/view/1117038/What-else-should-i-do-or-check.html ]
I switched out Air reg, IACV, TPS, MAF, O2's, water pipe sensors from my brothers car (no problems with his) take it out to warm it up and it was seeming like it was running great except the 1800-2000 idle. Let it run when i went in to get something to drink, came out started driving down the road and the rpms just went to zero. The more gas you gave the faster the motor stalled so i just coasted with it still in gear. I dont know what it could be or make that happen, any help guys with the old and new problem?
I've re-ohm'ed coils, injectors, IACV, Air Reg, TPS, CAS, O2's, PTU, No codes, can here the fuel pump, new fuel reg, sensors on the water pipe, boost/vac tested (no leaks) different dampner. Every time you drive/idle it for 30mins shut it off then try to start it, wont start without giving it gas at the right time then you gota hold it for ~30sec.
Sorry for the long annoying posts all i want to do is have my sweet ass z running again so i can enjoy it, been to long since i have done so. Any help is greatly appreciated.
Thanks
Buying things I don't need to impress people I don't know.
-ZNOEVIL-
