TwinTurbo.NET: Nissan 300ZX forum - Chasing a rough idle.. update.
Subject Chasing a rough idle.. update.
Posted by Draker (Eugene, OR) on August 06, 2010 at 7:11 PM
  This message has been viewed 304 times.
Message I posted a while back about a possible vacuum leak. Original post is here: La-Z-Link
Like I said in the first post I've boost tested it and fixed all the leaks I can hear. After getting some replies I just tested it again at 7 PSI as recommended. pressure dropped ~1psi every 10 seconds. So it took about 30 seconds to get to 4psi. The only leak I could hear was a slight hiss at the dipstick tube. If I pushed it in, it would go away.
My problem is still the same however. I've got a rough idle, and was wondering if there was anywhere there could be a leak that wouldn't be found on a standard boost leak test. I hear a hiss at the driver side rear of the intake manifold near the IACV/IAA however nothing during the leak test. This sound could be just air moving through the IACV I am guessing.
I am still boosting okay. Power balance is fine, just low unstable vacuum.
Any other ideas? I've done a 60k so most gaskets are new, plenum gasket is new, valve covers are new.
I have yet to tear the IACV off and inspect it, is it possible to have an internal leak?
Thanks in advance.
