TwinTurbo.NET: Nissan 300ZX forum - OHM the connection from the ECU
Subject OHM the connection from the ECU
Posted by 93DemonCar on May 15, 2008 at 9:24 AM
  This message has been viewed 360 times.
In Reply To Re: bad splice or injector (not the splice)..... posted by jmoept on May 15, 2008 at 12:02 AM
Message [ http://twinturbo.net/nissan/300zx/forums/technical/view/1052104/As-Audioquest-said-do-it-at-the-ECU-harness-first.html ]
Fill out your vehicle profile:
Disconnect the battery first.
Disconnect the ECU harness.
Continuity should be between 10 and 14 ohms.
Year 90-94
Injector 1 - ECU Pin 101 to ECU pin 58.
Injector 2 - ECU Pin 110 to ECU pin 58.
Injector 3 - ECU Pin 103 to ECU pin 58.
Injector 4 - ECU Pin 112 to ECU pin 58.
Injector 5 - ECU Pin 105 to ECU pin 58.
Injector 6 - ECU Pin 114 to ECU pin 58.
Year 95-96
Injector 1 - ECU Pin 101 to ECU pin 45.
Injector 2 - ECU Pin 110 to ECU pin 45.
Injector 3 - ECU Pin 103 to ECU pin 45.
Injector 4 - ECU Pin 112 to ECU pin 45.
Injector 5 - ECU Pin 105 to ECU pin 45.
Injector 6 - ECU Pin 114 to ECU pin 45.
