| Here is pinout info for the different years. The ECU harness is very easy to get to, will tell you which injector to go to first (no fun pulling injector connectors) and can help quickly identify a possible bad harness connection to the injector. Disconnect the battery first. Disconnect the ECU harness. Continuity should be between 10 and 14 ohms. Year 90-94 Injector 1 - ECU Pin 101 to ECU pin 58. Injector 2 - ECU Pin 110 to ECU pin 58. Injector 3 - ECU Pin 103 to ECU pin 58. Injector 4 - ECU Pin 112 to ECU pin 58. Injector 5 - ECU Pin 105 to ECU pin 58. Injector 6 - ECU Pin 114 to ECU pin 58. Year 95-96 Injector 1 - ECU Pin 101 to ECU pin 45. Injector 2 - ECU Pin 110 to ECU pin 45. Injector 3 - ECU Pin 103 to ECU pin 45. Injector 4 - ECU Pin 112 to ECU pin 45. Injector 5 - ECU Pin 105 to ECU pin 45. Injector 6 - ECU Pin 114 to ECU pin 45. Here's a link to the pinout of the ECU harness connector as viewed from the harness side of the connector. [ http://www.300zx.co.uk/cgi-bin/manual.cgi?list=efec&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=177&design=default&total=190 ]
