TwinTurbo.NET: Nissan 300ZX forum - BDE oil pan - anyone up for some welding porn?
Subject BDE oil pan - anyone up for some welding porn?
Posted by LitlElvis on August 05, 2021 at 8:05 PM
  This message has been viewed 659 times.
Message I finally found the time to put together my first oil pan and weld it completely. It's a mix of fuse welding (no filler rod) and silicone bronze brazing to reduce heat build up. 12 hours to assemble and spot weld everything, 10 more hours to fully weld all joints... I am happy with the end results.
Next up is machining the gasket surface flat and then a jig to press louvers into the windage tray and I will finally be able to offer these for sale.
If you're interested, here's the prototype post of the pan from February.
