TwinTurbo.NET: Nissan 300ZX forum - Because the ECU connector is downstream from the injectors
Subject Because the ECU connector is downstream from the injectors
Posted by 300zx90 (CO) on July 31, 2006 at 9:30 AM
  This message has been viewed 934 times.
In Reply To why not just repin it at the ecu connector? (n/m) posted by aliaZ on July 30, 2006 at 11:27 PM
Message More info here. Swapping pins on the ECU connector will have no affect on the power source for the injectors. The ECU provides a ground switch for each injector, not the power source.
________________________________________
NA to TT, starting from the ground up...
Proper check valve inspection per the FSM...
