TwinTurbo.NET: Nissan 300ZX forum - why not just repin it at the ecu connector? (n/m)
aliaZ
on July 30, 2006 at 11:27 PM
How-To: Injector Switched Power Line Using Fuse Box Tap
posted by jzack
on July 30, 2006 at 12:02 AM
jzack
00:02:31 07/30/06
Re: How-To: Injector Switched Power Line Using Fuse Box Tap
Slobo7x
10:28:41 07/30/06
Yes - when I cut the constant 12v going to the injector,
jzack
10:58:18 07/30/06
Re: Yes - when I cut the constant 12v going to the injector,
Slobo7x
17:06:02 07/30/06
Yes - someone a long time ago posted that the common
jzack
19:36:26 07/30/06
why not just repin it at the ecu connector? (n/m) -
aliaZ
23:27:36 07/30/06
details? (n/m)
zgene4
00:12:13 07/31/06
Because the ECU connector is downstream from the injectors
300zx90 (CO)
09:30:45 07/31/06
ok...thanks (n/m)
aliaZ
16:04:08 07/31/06
Where exactly did you splice your switched 12v into the
Audioquest
15:17:49 08/01/06
2nd
TheSlimOne
11:40:09 08/28/06
Alternate power source for cleaner install
Jehannum
09:04:07 08/28/06
