TwinTurbo.NET: Nissan 300ZX forum - ECU wiring for speed and rpm?
Subject ECU wiring for speed and rpm?
Posted by pierrez on July 08, 2006 at 12:58 PM
  This message has been viewed 216 times.
Message I spent several hours searching through posts, FAQs, FSM, and various associated docs. I must be doing something wrong because I was unable to find what's got to be some pretty damn simple info:
I just got a Defi VSD Basis speed/tach gauge (from Kuah at SPL -- he had the BEST price and shipped it the SAME day, props!!) and I can't figure out which ECU wires I need to splice into.
This is the USELESS info that came with the unit:
[ http://www.egauges.com/Defi/basis_install.html ]
The ECCS diagram in the FSM is hard to follow and even an experienced non-Z mechanic wasn't able to positively identify the correct wiring points.
The Basis has 4 wires to be attached:
1. Ground
2. +12V
3. Speed signal
4. RPM signal (they say to use primary ignition coil)
I found this post by CeeLo describing Blitz Powermeter installation but it does NOT make clear EXACTLY which ECU wire is the speed signal:
[ http://twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=995129 ]
Could someone either
(a) Tell me which colored ECU wires from which numbers of ECU harness positions are the speed and rpm signal wires I need to splice into?
or
(b) Point me to a page that I missed that shows this?
or
(c) Help me interpret the cryptic spaghetti diagram from the FSM?
Heeeeeeelp!
