TwinTurbo.NET: Nissan 300ZX forum - Hopefully you didn't break a valve doing the cam
Subject Hopefully you didn't break a valve doing the cam
Posted by thunderZ on June 18, 2006 at 12:06 AM
  This message has been viewed 80 times.
In Reply To I rotated the passenger side, and according to the write-up posted by NisVG 30 DE TT on June 17, 2006 at 09:41 PM
Message rotation that way. Couple of things come to mind:
If you had the plugs out, it makes it easy to turn the crank, so the crank could turn a little like wilkendw said.
It's not easy to turn the cams, so it would be tough to FEEL if you hit anything during rotation.
That said, I hope wilk was right in saying that maybe the piston moved a little to prevent a valve from breaking. If you rotate the crank, it's obvious if you're hitting a valve.
Did the teeth count check out?
