TwinTurbo.NET: Nissan 300ZX forum - Re: Ok, maybe that is it. I didn't move it backwards.
Subject Re: Ok, maybe that is it. I didn't move it backwards.
Posted by wilkendw on June 17, 2006 at 4:06 PM
  This message has been viewed 102 times.
In Reply To Ok, maybe that is it. I didn't move it backwards. posted by NisVG 30 DE TT on June 17, 2006 at 04:00 PM
Message you mean you rotated the cam sprocket almost 360 degrees to get it back to it's original position? Not good... In theory this would cause valve interference with pistons - possibly bending valves. I'm not sure if you can bend valves when rotating the cam by hand, or if it would take more force than possible with hand pressure. Hopefully you didn't use a lever?
