TwinTurbo.NET: Nissan 300ZX forum - Re: Update 4: Ughh, did I kill my car or what?
Subject Re: Update 4: Ughh, did I kill my car or what?
Posted by wilkendw on June 17, 2006 at 4:00 PM
  This message has been viewed 85 times.
In Reply To Update 4: Ughh, did I kill my car or what? posted by NisVG 30 DE TT on June 17, 2006 at 02:37 PM
Message no. resetting cam as you did won't cause a problem. roughness is probably a miss as you say, maybe a dead cylinder - do a balance test, check connectors, swap coil packs, etc. Also make sure the harness is properly routed and connected to matching cylinders... Idle/stalling could also be due to vacuum leak - try running a boost leak test to see if you can find any loose/leaking connections.
