TwinTurbo.NET: Nissan 300ZX forum - Hum, I wouldn't rely on this assumption
Subject Hum, I wouldn't rely on this assumption
Posted by RomChip200 on April 13, 2006 at 5:57 PM
  This message has been viewed 430 times.
In Reply To How to tell the difference between NA and TT fuel pumps posted by JTurbo@Z1 on April 12, 2006 at 06:14 PM
I'm not sure this # means what you mean ...
Did you check the same numbers on many TT and NA !?
I just removed my TT fuel pump (2+2 euro spec) and the number is B78 ....
I will remove tomorrow a NA pump I fitted in my tank by mistake and tell you the number I will discover ...
To my mind, the fuel pump itself is the same between NA, TT and some others Nissan cars, only the mechanical assembly differs. I wouldn't understand why Nissan would do different product lines for the same pump finally as what is noticeable with Nissan is they use the same parts with different parts # for many cars(cost reduction).
Only some real flow tests would allow to highlight a diff between NA and TT fuel pumps.
