TwinTurbo.NET: Nissan 300ZX forum - Re: Symptoms of a head gasket leak
Subject Re: Symptoms of a head gasket leak
Posted by wilkendw on March 09, 2006 at 5:17 PM
  This message has been viewed 185 times.
In Reply To Symptoms of a head gasket leak posted by JayT on March 09, 2006 at 03:01 PM
Message sorry to hear of your problems. 2K is too much to replace a head gasket. By now I'd guess the best advice would be to find a better mechanic. If they didn't set the timing right and you boosted/detonated, that would be their bad... Overheating could have any number of causes but over advanced timing will contribute. Don't know what agreement you had with the mechanic, and I can sympathize with his postion too - he obviously didn't know what he was getting into. Messy situation. Here's my advice
Compression check engine
Look for coolant in oil and HC's in coolant
If engine is blown, don't waste time on head gasket etc.
If the engine was overheated as you say, heads could be warped, require machining etc.
