Neat ;) (n/m) posted by thumper300zx on December 16, 2005 at 12:49 PM
sleeve any further than it was before. You marked it and put it back in the same spot so you should be fine. The reason that Audiquest's probably failed is someone didnt know hte diff and hammerd it on with a impact gun pulling the pinion gear out of spec. More than likely you are hearing your diff more do to the harder busings. It happens alot with the Poly bushings. Seems every one that puts them in (subframe busings also) complains right after that "My rearend is noisey"
