lift mechanism, remove the two window hardstops at the top of the door, remove the plastic outer cover on the upper part of the door, and the glass slides out the top. Mine took a little tugging to get it out the top of each track (there are three tracks) and likewise to get it back in each track. Perfect time to change the caps on each of the rollers and cure any window rattles :)
________________________________________ NA to TT, starting from the ground up...
