TwinTurbo.NET: Nissan 300ZX forum - It is a Rockwell Superficial hardness test. It involves usi
Subject It is a Rockwell Superficial hardness test. It involves usi
Posted by Ash's Z on December 02, 2004 at 4:11 PM
  This message has been viewed 502 times.
In Reply To Do you remember what scale the Hardness machine was on? (n/m) posted by yawgm0thzx on December 02, 2004 at 03:30 PM
Message using a diamond tipped 'punch'. With a differing amount of loading applied to it over 3 loadings, you can measure the hardness of the material by the depth of the indention.
HR=E-e
e = permanent increase in depth of penetration due to major load F1, measured in units of 0.001 mm
E = a constant of 100 units for diamond and ball indenters
HR = Rockwell hardness number
In the case of the soft valve (which is actually a little harder), the loading applied was 45Kg. E=100 and units of e are 0.001mm. The diamond punch left an impression difference of 0.068mm, or 67 units.
HR = E-e
=100-68
=32
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
