TwinTurbo.NET: Nissan 300ZX forum - Power steering (ps) hose replacement procedure
Subject Power steering (ps) hose replacement procedure
Posted by doug8867 on September 03, 2004 at 6:46 PM
  This message has been viewed 18766 times.
Message ince I could never find a definitive write-up on replacing a ps hose I thought I would post the procedure I used in the hopes that it might help someone else in the future.
This is the procedure to replace the Power Steering hose on a Twin Turbo z. The procedure will also work on an N/A and will be easier as there will be less hoses to remove. Unfortunately, failure of the high pressure hose seems like a fairly common problem on z cars as they begin to show their age. If left unchecked, a leaking hose can also cause your alternator to fail as well, so living with a leaking hose is not an option. Also be advised that this is a dirty, tedious job.
Timing:
After first noticing reddish liquid spots beneath the U.S. passenger side of the engine bay and/or the HICAS light begins to come on intermittently (applicable to 90 -93 cars only), letting you know your fluid is low, and you've confirmed visually that the hose is leaking. This is usually fairly obvious when viewing the hoses from under the car as ps fluid will be covering and dripping from a lot of places when the high pressure hose leaks as it tends to spray fluid everywhere.
Tools/Parts Needed:
High Pressure Power Steering Hose (Part # 49720-31P00)
1 qt. ATF (automatic transmission fluid) Dextron type III
Flat head screwdriver
Phillips head screwdriver
19mm wrench
10mm wrench or socket
23mm socket
1/2" ratchet
6" 1/2" extension
needle nose pliers (removing hose clamps)
x-acto knife (needs to be narrower than a standard utility knife to reach in small spaces)
oil drain pan or some other container to catch ps fluid
Two 2" x 6" at least 10" long (for driving the front tires on to elevate the car so the floor jack can get under it from the front)
Floor jack
Tools Recommended:
2 small copper crush washers (Part # 49726-50W00 $1.50ea. from czp.us)
2 medium copper crush washers (Part #49726- Y0100)
21mm socket (for quicker and easier removal of tire rather than using the standard car jack)
18" 1/2 breaker bar (to use with the 21mm socket on removal of front tire)
small flashlight (for spotting zip ties)
mechanics mirror on stick (for checking re-assembly of boost hose)
jack stands
Several rags on hand as this is a messy job
Estimated Time to do job:
4 - 5 hours including clean up your first time
First, drive your car up on the pieces of wood or similar elevation. This is to allow room later for sliding the floor jack under the car from the front without hitting the spoiler.
1. Remove the two large passenger side turbo hose/pipe and two small hoses outlined in yellow and indicated in the photo using the flat head screwdriver to loosen the hose clamps circled in red.
Also remove the two small hoses that attach to the intercooler hard pipe.
2. I put a piece of tape on both the hose and nipples to remind me later to hook them back up. ()
It's also a good idea to stuff a rag or two into the hose openings so nothing gets in there. If you have an NA, then obviously you don't have to worry about the boost hoses. Once the hoses are removed you can see the bolt circled in yellow.
3. Jack the U.S. drivers side up and remove the front wheel using normal safety procedures. This will allow you to see the bolt (Circled in Yellow) that holds the hose to the steering rack and also give you more room to work. ()
Place the 19mm wrench on the bolt and then use the small sledge to give it several sharp blows to loosen the bolt counterclockwise. This was the hardest part of the job for me, as it is difficult to get any real leverage while keeping the wrench on the narrow bolt head, but stay persistent and it will eventually come loose. Note the fact that there are 2 copper washers, one on each side of the hose connector that will need to be retained (if not purchasing new ones) and used on the install of the new hose.
4. Once it is loose, fluid will begin to ooze out so be sure and have your oil pan/other container underneath to catch the fluid. It should drain fairly quickly (2-3 minutes).
Also at this time, you will need to locate the sensor connector that is attached to the hose and disconnect it by pulling out on the small tab located on the side while at the same time pulling it apart. Look at your new hose sensor to get an idea how it works. Once again, because of the tight space it is difficult to get your hands on it with any kind of leverage (as they will no doubt be covered in grime and fluid at this point) but stay persistent.
5. In this same area are 3 small white zip ties that hold the sensor wiring to various hard pipes around the suspension. These are fairly difficult to see and reach, but once you've located them using the flashlight, you should be able to insert the narrow x-acto knife in the available spaces and "stab and nick" at the ties until they are cut. Until you cut these ties, you will not be able to remove the ps hose so it has to be done.
6. There is also, at least on my 90tt, another metal/rubber bracket (A) in this area that held the metal part of the ps hose and another hose side by side.
It also needs to be loosened using a philips head screwdriver to loosen the screw in it. Once it is unscrewed enough the metal back of this bracket will fall off leaving the hoses connected by the rubber part. You'll then need to wiggle the ps hose until you get the other hose to disengage from the bracket so that you can snake the ps hose out later.
7. Next, while you are under the car, there are 2 two hose brackets located near the center of the car on the cross member.
These are attached by 10mm bolts that need to be removed using the wrench or ratchet. These are fairly easy. There is also a plastic connector attached to one of the brackets that will need to be cut also.
8. After all the ties and bolts mentioned above have been removed/loosened you are now almost ready to begin wiggling and snaking the rack connection side of the hose onto the ground. (more fluid will seep out of the hose now) But prior to doing this, make a mental note of how the hose is positioned in relation to other hoses, etc. as you will have to snake the new hose and sensor into the exact same position or else it will not fit.
7. Once you've got the rack side of the hose loose and dangling on the ground, move out from under the car and use the 23mm socket, 6" extension, and the breaker bar to loosen the bolt on the pump. This will seem like cake compared to the rack bolt. Once again, make sure to retain the 2 copper washers and make a note of how the hose comes up from the bottom as it will have to be installed in exactly the same way.
9. Cut the black zip tie holding the hose to the electrical harness next to it and then push and wiggle the hose down towards the ground as far as possible. Then get under the car again and pull it the rest of the way out.
10. Transfer the hose brackets from the old hose to the new hose in the same locations.
(It's probably not necessary to transfer the side by side bracket (A) as there is no way to insert the other hose back into it, but I transfered it nonetheless)
11. Keep the plastic inserts that came with the hose in the connectors to prevent dirt from getting in the hose. I also put a small piece of tape around the sensor wire and hard pipe to make it easier to snake back through and another piece over the sensor connector to keep out dirt.
12. To install the new hose, start by snaking the new hose on the rack side first. This will take some more wiggling and pushing and pulling to get it to the proper position. Once there, insert one washer, then the hose connector, washer and bolt and tighten. Again, this may take a little tweaking to get the bolt lined up properly due to the awkward angle but be patient. Use some muscle and tighten the bolt as tight as you can using the breaker bar. A torque wrench would have been nice to use but I couldn't get enough room to fit a socket head and the torque wrench over the bolt, so I had to use the regular wrench
13. Remove the tape on the sensor harness and connect it.
14. Now snake the hose up on the other side up to the pump connection taking care to install it along the same route, and between the same hoses it came out. Insert the washers on each side of the hose connector and tighten the bolt.
15. Reinstall all boost hoses. The bottom intercooler hose is a little tricky and will need to be "shortened" by compressing it slightly to force it back in place. Take care that you have the hose rim over the connecting pipe and not bent as this will cause an air leak. I was able to be sure mine was firmly attached using a mechanic's mirror and the flashlight.
16. Reinstall the tire and lower the car.
17. Slide the floor jack under the center of the car and lift the car using the crossmember between the wheels as the lifting point, until both front wheels are off the ground an inch or so.
18. Fill the ps resevoir with ATF fluid until it meets the minimum mark. Mine took a little over a pint. Leave the resevoir lid off.
19. Start the car and then turn the wheels side to side until they lock and repeat for 3 or 4 times. This is to bleed the system. Check the fluid level and top off to the minimum mark. Do not over fill. Turn the wheels again, and then check the fluid level once more.
20. Monitor the fluid level over the next several days of driving and add a little more if necessary.
Hope this helps someone else,
doug8867
Special thanks to members "Moxie" and "Joe(NoVa)" who gave me some pointers during my first attempt at this job.
