TwinTurbo.NET: Nissan 300ZX forum - Dual-pop w/ stock ECU ? Warning ! Stop driving immediately !
Subject Dual-pop w/ stock ECU ? Warning ! Stop driving immediately !
Posted by Dark Diver on April 19, 2004 at 4:40 AM
  This message has been viewed 387 times.
In Reply To Re: as long as you have ecu... or afc posted by MarineZ on April 19, 2004 at 03:44 AM
Message If you have a dual-pop, you need a specific EPROM for it, because the MAS reads only half the airflow.
Stillen ECU is the same as JWT. Is it the EPROM for dual-pop ? If not, your engine is running very-very lean and it's the reason why you got engine warning (detonation) and under power (too lean, safety maps, but not safety boost because you have an EVC).
Stock boost w/o stock solenoids should be around 7 psi (stock wastegates springs). If you reach 15psi with your EVC off, you may have a vacuum leak.
YES, 15 psi with stock internals is safe... if you have the right EPROM.
