Subject |
Replace all of your injectors, if two are bad, ..... |
Posted by |
FireMedicZ on August 02, 2003 at 10:00 PM |
This message has been viewed 130 times. |
In Reply To |
Very hesitant before 3000 rpm posted by Cmos on August 02, 2003 at 02:07 PM |
Message |
the rest are not far behind. Murphy's Law, if you go through all the labor involved in removing the plenum to replace just the two bad injectors, then within two days of getting your Z running, another will go out. Replace them all, do the throttle coolant line bypass, and replace your fuel lines. Regarding the hesitation, another thing to check is your ECU codes, if you get a code 34 (Knock Sensor) it will retard your timing up to 3k, after 3k timing goes back to normal, I think.
Follow Ups |
Post a Followup |
