TwinTurbo.NET: Nissan 300ZX forum - Check the EGR valve it might be stuck open a small
Subject Check the EGR valve it might be stuck open a small
Posted by ZUL8TR on August 02, 2003 at 4:21 PM
  This message has been viewed 203 times.
In Reply To Very hesitant before 3000 rpm posted by Cmos on August 02, 2003 at 02:07 PM
Message amount. Also do a vacuum test with the engine warmed up and running. At idle should read a very steady 19"Hg and at 2000 rpm a very steady 20.5"Hg (these are my 92 NA readings, same since 1992 and now at 73K miles). Vibrating needle indicates a problem the larger the vibe the worse the problem. Research a repair manual or the instructions for the vacuum gage for needle interpertations.
ZUL8TR in Orlando,FL
