TwinTurbo.NET: Nissan 300ZX forum - One thing that needs correction-->
Subject One thing that needs correction-->
Posted by Kyle(Houston) on June 05, 2002 at 7:04 AM
  This message has been viewed 917 times.
In Reply To Updated NA to TT conversion stuff (all the info you need) posted by Ruzzell on June 04, 2002 at 11:16 PM
Message I didn't have time to read the whole thing but skimming through it I found this one mistake.
12. The throttle bodies are the same size but the passenger side one is different on a TT simply because one of the water lines attached to the bottom of it has a junction in it to feed water to one turbo. But we usually do away with all that nonsense with the water lines under the plenum running to the TB's in our warm climate. We just run water to and from the metal hoses on the back of the motor going to and from the heater core.
Actually it is the driver side that is different. Also the TPS sensor is a little different but I have not looked into it enough to say what the difference is.
Nice job Russell!!!
Kyle "Grumpy Bear" Puckett
ICQ #727815
Click here to E-mail SGP Performance!Click here for SGP Performance!
