TwinTurbo.NET: Nissan 300ZX forum - + extra little stuff
Subject + extra little stuff
Posted by damaged(pittsburgh) on November 19, 2001 at 10:10 PM
  This message has been viewed 910 times.
In Reply To NA & TT differences and swap facts I have been compiling>> posted by Ruzzell on November 19, 2001 at 07:37 PM
Message for the sake of people using this faq as a bible, if i remember this stuff correctly...
you only need to swap the 'fatter' ac lines (2), i forget if they are the high or low pressure....the others can be bent to fit as long as you don't crimp them.
and na's need a tt vacuume res. that goes to the fuel dampner and an extra solenoid, which is the same as the egr solenoid.
the na cold air intake metal pipes (the ones off the rubber Y) are different...actually they are similar, but the place where the recircs plug in is larger on na's.
