TwinTurbo.NET: Nissan 300ZX forum - I ran into this myself with poly bushings
Subject I ran into this myself with poly bushings
Posted by Polishzx on May 01, 2026 at 2:45 AM
  This message has been viewed 95 times.
In Reply To Rear toe angle bushing...I've got a twin turbo and posted by not4resaleZ on April 30, 2026 at 05:15 PM
Message It seems the toe-arm bushing slot on the knuckle-side of the TT is actually slightly bigger because a ball joint was located there, rather than just a bushing on NA knuckle. Looking on CZPs site, the model you purchased I would have thought is correct, but maybe it is for NA only. You could try the non-nismo version which appears to be available, but again it might be for NA which could be smaller. La-Z-Link https://conceptzperformance.com/nissan-infiniti-nissan-oem-rear-toe-arm-bushing-knuckle-side-nissan-300zx-91-96-z32-55152-33p01_p_28163.php
When I ran into this, I found the same thing where the rear knuckle-side toe arm bushing slot was a little too large for the bushings in the whiteline kit. However, I had a bizarre stroke of luck where I received the correct bushings for the TT knuckle-side toe arm slot in a mis-labeled bag. You could try getting a hold of whiteline and see if they can special order this bushing photographed here: La-Z-Link [ http://twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=2657974 ]
