TwinTurbo.NET: Nissan 300ZX forum - Rear Washer Not Working
Subject Rear Washer Not Working
Posted by AZ_300_ZX on March 10, 2026 at 9:12 PM
  This message has been viewed 82 times.
Message Front washer + wipers work fine. Rear wiper works fine. Rear washer fuse is good and reservoir sensor is working however the rear washer does not function at all, motor does not run.
I've disassembled the washer fluid tank to access both motors (fun fact: neither of these is for the front washer; presumably one is for the rear and the other for the non-existent headlight washer according to ChatGPT) and using a multi-meter it seems neither connector is getting power when switched on.
In any case, under a number of different tests it seems there is no power getting to these pumps. I've even "jiggled" the wiring conduit/loom for the rear lid with the switch on, no luck. I have not yest tried connecting power directly to the motors, but will to rule the motors being faulty out.
Anyone else have experience troubleshooting this one?
Thx,
JTW
