TwinTurbo.NET: Nissan 300ZX forum - Re: Voltage drops
Subject Re: Voltage drops
Posted by Kvert on January 24, 2026 at 3:15 PM
  This message has been viewed 111 times.
In Reply To Voltage drops posted by Hiruzaiz32 on January 19, 2026 at 06:49 PM
Message Check both with multimeter.
With car off, you should see ~12V at the battery. Ideally a bit higher. If this is true, battery is likely good.
With car running you should see ~14V at battery. If not, alternator may be bad (usually voltage regulator, but still requires replacement of whole unit)
