TwinTurbo.NET: Nissan 300ZX forum - Re: Re: CAS replacement and Reluctor
Subject Re: Re: CAS replacement and Reluctor
Posted by RHD NOVA on January 07, 2026 at 10:58 AM
  This message has been viewed 105 times.
In Reply To Re: CAS replacement and Reluctor posted by Kvert on December 18, 2025 at 09:19 AM
Message Hi Kvert. CAS was working fine, but removed it to update to a VR sensor. To see if the VR snesor was faulty i reinstalled the stock CAS and still no start. I did before the reinstall cleaned the CAS pins and added a new plug ( with the correct wires) just in case that was the issue. Same deal. Car turns over, but no start.
I just ran a new shielded wire run from the VR sensor to the 42/50 pin and grounded the shield wire to the chassis near the ecu. Getting a solid and clean signal, but still no sync to the degree I dont get a timing light. Was hoping someone on here used the NZ wiring CAS or even the SZ hall sensor and had some experience with the no start issue.
