TwinTurbo.NET: Nissan 300ZX forum - CAS replacement and Reluctor
Subject CAS replacement and Reluctor
Posted by RHD NOVA on December 15, 2025 at 2:48 PM
  This message has been viewed 206 times.
Message Happy holidays all!
Since the onset of winter my Z is now under the knife for general mods and maintenance. One sensor I'm replacing is the CAS and i'm having such fun chasing down grounding issues and sensor noise to get the reluctor cam sensor to work ( running Link ECU). I'm about to run dedicated shielded wire from the sensor to the ecu in hopes of cleaning up what has been a very noisy trigger scope ( after re-grounding the starter, block, battery, and finally to the chassis). I'm using the NZ wiring kit and wanted to see if anyone else has experience with the kit or a reluctor ( not hall effect) cam signal and if so what were your general offsets for timing ( did you also have any issues with siensor noise). thanks
