TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel Tank Rubber Fuel Hoses
Subject Re: Fuel Tank Rubber Fuel Hoses
Posted by Brainzed on September 20, 2025 at 3:39 PM
  This message has been viewed 2338 times.
In Reply To Fuel Tank Rubber Fuel Hoses posted by rhombicblue on September 17, 2025 at 09:27 PM
Message It's a tight squeeze. I haven't accomplished this task without dropping the tank, but if I had to do it with tank in car, I would use long hose lengths and a drop or two of oil to help the hose slide onto the hard lines - don't forget to add your clamps first. The longer hose length will help you twist and push the hose on without having your fingers crammed in the tight space. Then cut the hoses to the proper length, lube them up and slide them onto the fuel pump lines.
