TwinTurbo.NET: Nissan 300ZX forum - How did this issue manifest before you took the engine apart
Subject How did this issue manifest before you took the engine apart
Posted by Polishzx on September 15, 2025 at 12:26 AM
  This message has been viewed 3870 times.
In Reply To Re: Re: Engine binding on rotation in certain spots posted by zman03 on September 09, 2025 at 08:05 PM
Message Did it have a hard time starting or something? Otherwise the binding you're describing sounds normal when trying to manually rotate the crank because of compression in the cylinders, assuming your spark plugs were still installed when rotating. I think slipping a single tooth would only cause very poor running, there would have to be a much more severe timing belt slip/issue to actually cause interference damage.
