TwinTurbo.NET: Nissan 300ZX forum - Coolant bypass question
Subject Coolant bypass question
Posted by Hiruzaiz32 on September 02, 2025 at 3:58 PM
  This message has been viewed 6021 times.
Message https://photos.app.goo.gl/FeXBjnC9orXPjEvK6
1994 NA Hello everyone, there are two 8mm (or 5/16th) nipples that come out from both of these heater core pipes. My question is.. is there any problem with routing the two small nipples together? The heater core bypass also allow for the large pipes to connect so couldn't its two small nipples too?
I've already done the coolant bypass for an NA however further along the reroute that leads behind the engine has developed a huge coolant leak from behind the engine on a small rubber hose I cannot comfortably reach. This is my daily and I cannot pull the engine. Is connecting the heater cores 8mm inlet and outlet nipples be okay?
