TwinTurbo.NET: Nissan 300ZX forum - Sometimes it is possible to dig
Subject Sometimes it is possible to dig
Posted by Denis on August 29, 2025 at 1:21 PM
  This message has been viewed 5954 times.
In Reply To Re: OK, disregard my earlier suggestions posted by acetrebo on August 28, 2025 at 10:53 PM
Message the brass ones when pounding them into the crank end. That will cause the pilot shaft to drag and keep turning. Been there, done that.
Not sure if you had a tool or dummy pilot shaft to line the clutch up while tightening the pressure plate, but whatever you used should have slid easily into and out of the brass bushing after installing the bushing. If not, then you found the likely source of your problem.
As a side note, the roller bearings can seize as they get older and when they do it tears up the pilot shaft. At least the brass is graphite impregnated and will just get sloppy when it is old and worn.
