TwinTurbo.NET: Nissan 300ZX forum - The stock ones can flex but I don't think enough to not get
Subject The stock ones can flex but I don't think enough to not get
Posted by Polishzx on August 28, 2025 at 12:49 AM
  This message has been viewed 5961 times.
In Reply To Re: Agreed, I think it would be best to pull the trans again posted by acetrebo on August 27, 2025 at 11:58 PM
Message into gear. It does make things feel better, but I doubt it will solve this problem. Did you do the clutch pedal adjustment from the SpecialtyZ write-up, where you adjust the rod that is connecting the pedal to the master cylinder? Also, you're bleeding the top-passenger side port when bleeding clutch system, right?
