TwinTurbo.NET: Nissan 300ZX forum - Agreed, I think it would be best to pull the trans again
Subject Agreed, I think it would be best to pull the trans again
Posted by Polishzx on August 27, 2025 at 4:46 PM
  This message has been viewed 5969 times.
In Reply To Likely installed clutch disc in backwards - However, check posted by Ghoztt (MD) on August 27, 2025 at 10:56 AM
Message and investigate the clutch disc and pressure plate for any issues, before trying to replace the master and slave. At the same time, you can upgrade to the 350Z HD clutch fork kit which I doubt will solve your problem, but be an upgrade to shifting regardless of clutch you run.
