TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Need clutch help
itsa300zx
on August 26, 2025 at 5:38 PM
posted by acetrebo
on August 26, 2025 at 05:08 PM
OEM clutch fork? might be flexing more because of a stronger pressure plate.
Need clutch help
acetrebo
14:27:05 08/26/25
acetrebo
16:07:59 08/26/25
acetrebo
17:08:33 08/26/25
Re: Re: Need clutch help -
itsa300zx
17:38:49 08/26/25
Re: Re: Re: Need clutch help
acetrebo
18:01:59 08/26/25
Re: Re: Re: Re: Need clutch help
acetrebo
22:23:31 08/26/25
Any updates for us on your clutch release issue?
itsa300zx
11:30:40 09/15/25
Likely installed clutch disc in backwards - However, check
Ghoztt (MD)
10:56:58 08/27/25
Agreed, I think it would be best to pull the trans again
Polishzx
16:46:35 08/27/25
Re: Agreed, I think it would be best to pull the trans again
acetrebo
23:58:01 08/27/25
The stock ones can flex but I don't think enough to not get
Polishzx
00:49:06 08/28/25
Re: The stock ones can flex but I don't think enough to not get
acetrebo
08:05:51 08/28/25
Re: Re: The stock ones can flex but I don't think enough to not get
acetrebo
08:16:33 08/28/25
Re: Likely installed clutch disc in backwards - However, check
acetrebo
23:54:21 08/27/25
Sadly, it can and has been done.
Ghoztt (MD)
14:08:08 08/28/25
Re: Sadly, it can and has been done.
acetrebo
18:34:37 08/28/25
acetrebo
00:00:07 08/28/25
Where are you in the "USA" ? One of the Z community
Denis
11:08:56 08/28/25
Re: Where are you in the "USA" ? One of the Z community
acetrebo
18:36:55 08/28/25
I may have my head on backward on this but
Denis
11:51:33 08/28/25
The bottoming out sounds like physical interference inside
Ghoztt (MD)
14:16:48 08/28/25
Re: The bottoming out sounds like physical interference inside
acetrebo
18:43:22 08/28/25
The bottoming out term I used
Denis
20:41:15 08/28/25
Re: The bottoming out term I used
acetrebo
22:22:06 08/28/25
Re: I may have my head on backward on this but
acetrebo
18:41:01 08/28/25
Re: Re: I may have my head on backward on this but
Denis
20:56:53 08/28/25
Re: Re: Re: I may have my head on backward on this but
acetrebo
22:13:40 08/28/25
OK, disregard my earlier suggestions
Denis
22:41:11 08/28/25
Re: OK, disregard my earlier suggestions
acetrebo
22:49:37 08/28/25
acetrebo
22:53:34 08/28/25
Sometimes it is possible to dig
Denis
13:21:13 08/29/25
Make that ding (n/m)
Denis
13:24:01 08/29/25
Re: Sometimes it is possible to dig
acetrebo
13:47:41 08/29/25
Good Luck! (n/m)
Denis
16:43:25 08/29/25
Re: Good Luck!
acetrebo
21:32:04 08/31/25
You most likely said, but did you replace the
Denis
23:59:07 08/31/25
Re: You most likely said, but did you replace the
acetrebo
08:18:16 09/02/25
mrchips
06:18:21 08/31/25
acetrebo
08:21:28 09/02/25
clutch update
acetrebo
08:05:30 09/22/25
Re: clutch update
acetrebo
23:27:13 09/30/25
What exactly was the problem. Bent fork? TIA. (n/m)
mrchips
07:49:44 10/01/25
