TwinTurbo.NET: Nissan 300ZX forum - Re: Need clutch help
Subject Re: Need clutch help
Posted by acetrebo on August 26, 2025 at 5:08 PM
  This message has been viewed 181 times.
In Reply To Need clutch help posted by acetrebo on August 26, 2025 at 02:27 PM
Message So, I backed of the switches at the top of the pedal, and then adjusted the pedal up so they just close, as the writeup said.
However, still have the same problems.
Looking at the slave and clutch fork, I dont seem to have any play as it should. The slave is pushing on the fork just enough I think to lightly hit the clutch fins. The previous procedure was supposed to help with this. So I am still stumped. Going to try to bleed the slave more to see if it frees up a little. But regardless, when clutch is fully depressed, it does not appear to be pushing on the fork far enough to release the clutch.
