TwinTurbo.NET: Nissan 300ZX forum - Timing and aftermarket CAMS
Subject Timing and aftermarket CAMS
Posted by RHD NOVA on April 08, 2025 at 3:21 PM
  This message has been viewed 3947 times.
Message Doing a bunch of maintenance on my Z and decided to check the timing since the CAS seem to be WAAY biased counter clockwise ( visually). Hooked up the timing light and saw 13 to 15 degrees, very bouncy. Ignition timing Via laptop is ~15 as well. I just seems really odd that it is so biased to left and runs and tests fine. The car has Tomei Cams and def has a cammy idle. Could this be the reason for the CAS setting?
