TwinTurbo.NET: Nissan 300ZX forum - Thanks a bunch.
Subject Thanks a bunch.
Posted by Doug71zt(CAN) on April 06, 2025 at 8:14 PM
  This message has been viewed 3756 times.
In Reply To 11mm od x 2.5mm hole. posted by itsa300zx on April 05, 2025 at 04:58 PM
Message I’m thinking it is absolutely required in the hose.
True the oil cooler circuit only has flow above 50-ish PSI due to the valve in the filter tree, but it is a total loss through the cooler into the pan. Big difference between an 8mm ID hose and a 2.5mm orifice flowing into the sump.
I think with journal bearing turbos, there is so much flow demand without an orifice installed in the hose that the oil pressure will probably never exceed 50-55 psi except on a cold start. Therefore, the cooler circuit will likely never function correctly anyway.
I will burn a couple out on the lathe and install one on this car.
