TwinTurbo.NET: Nissan 300ZX forum - Is it the correct belt for the pulley?
Subject Is it the correct belt for the pulley?
Posted by Polishzx on January 27, 2025 at 4:10 PM
  This message has been viewed 620 times.
In Reply To Power Steering Pulley Misaligned posted by TTwinTTurboZ on January 27, 2025 at 01:37 PM
Message For example, 4 rib belt going on a 4 rib pulley. Not a 4 rib belt going on a 3 rib pulley? Otherwise it looks like the belt may have not been centered on the pulley when tensioned, and is resting on the lip. You should be able to loosen the tension on the belt, slide it on correctly, then re-tension.
