TwinTurbo.NET: Nissan 300ZX forum - ASCD actuator failure
Subject ASCD actuator failure
Posted by arkansasturbo on October 14, 2024 at 3:17 PM
  This message has been viewed 758 times.
Message The CC has stopped working. I have good stoppers on every switch on the pedal. Switches work verified over at the control unit harness plug.
So following this:
[ http://twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=1154055&forum=technical&dtSearch=0 ]
I tested the ASCD actuator per EL-99. Step A operates the pump, Step B fails, no cable retracting.
Bought a used one that also passes A, fails B.
Bought a second used one that ALSO passes A, fails B.
I've completed these tests with alligator clips as well as crimped connectors on to spare wire and plugging straight to the actuator pins.
What are the odds I've got three actuators that fail the test? Slim to me....what now?
'90 TT MT
