TwinTurbo.NET: Nissan 300ZX forum - a/c and signal/hazard lights connected?
Subject a/c and signal/hazard lights connected?
Posted by VinZmax on October 12, 2024 at 12:24 PM
  This message has been viewed 766 times.
Message Hi Everyone,
I'm reaching out before I get into deep troubleshooting, to see if there's a quick answer.
I just got back from a short Saturday morning coffee drive. I noticed that my signal lights are not working. Hmmmm. I continued on and got coffee and then returned home.
Now, I found that on the way home it was getting a bit warmer and my a/c (auto style a/c on a '93 TT) was not working as well. What the heck?
So in my garage now, I find that the a/c has not power on the controls. Nothing. No fan, not digital readout, nothing.
My signal lights do not work.
My hazard lights do not work.
All else on the car works fine and drives fine. This all worked last weekend when I went to Cars and Coffee. All worked. A/C and signals worked, but did not try hazard lights as there was no need to.
So, anyone have this issue pop up out of nowhere? I'm wondering if it's the a/c pod or something and being that the hazard light swith is attached to that, if there's something wrong there and therefore causing my signal lighting to not work.
I did not do much troubleshooting as I just got home, but I did check under the hook fuses and so far pulled off the internal fuse cover and I'm ready to check some fuses.
Again, before I blow a Saturday morn fooling around, I want to know if someone has had this happen before and if there's an 'easy' answer.
Thanks,
Vinnie
(electronic engineer by the way, so I'm familiar with electronics/mechnics, and electro-mechanical systems but looking for the 'quick answer' for now if there is one).
