TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Engine wiring harness install
Subject Re: Re: Engine wiring harness install
Posted by lleron on September 13, 2024 at 2:44 PM
  This message has been viewed 501 times.
In Reply To Re: Engine wiring harness install posted by zwzweston on September 10, 2024 at 12:12 PM
Message I also replaced the harness with the engine in, and it honestly wasn't as bad as people make it out to be. Removing and reinstalling the bracket that holds the harness by the brake master cylinder was the hardest part.
As also mentioned, getting the ECU connector through the firewall wasn't fun either, but I didn't remove the dash. I "ovaled" the hole by bending the opening slightly so the connector could fit through at a downward angle, but I didn't remove any material and was able to bend it back flat and install the grommet without issue after.
