TwinTurbo.NET: Nissan 300ZX forum - Re: If ECU tune is set to Dual Intake, should you use add or avg
Subject Re: If ECU tune is set to Dual Intake, should you use add or avg
Posted by itsa300zx on August 02, 2024 at 10:50 AM
  This message has been viewed 447 times.
In Reply To If ECU tune is set to Dual Intake, should you use add or avg posted by TTkeeper on August 01, 2024 at 05:47 PM
Message ADD if “oem” 0-5v Maf scale is used, true plug n play, <500 hp.
AVE if ecu is tuned for “ dual pop” 0-2.5 V Maf signal, >500hp
These translators cut each of the Maf voltage in half.
You need to ADD them for a “oem” 0-5v signal.
You need to AVE them for a 0-2.5v signal to the ecu allowing the system to meter more air in the “dual pop” mode.
In your case, set to AVE
Hope that helps.
