TwinTurbo.NET: Nissan 300ZX forum - Think about putting some dialectric grease in all important
Subject Think about putting some dialectric grease in all important
Posted by Polishzx on July 09, 2024 at 3:10 AM
  This message has been viewed 416 times.
In Reply To Stumble stuttering when TT engine cold posted by AL on July 06, 2024 at 12:02 PM
Message engine connectors. Clean out the connectors with electronic contact cleaner and then put a little bit of dialectric grease in fuel injector connectors, coil pack connectors, maf connector, CAS connector, coolant connectors, PTU connectors, TPS connectors, idle connectors, etc, everything that the car needs to run well. Something that is worth doing anyways even if you don't have a problem, but this could solve a connector with a bad connection due to a little corrosion somewhere.
