TwinTurbo.NET: Nissan 300ZX forum - I had a similar problem 2 different times...
Subject I had a similar problem 2 different times...
Posted by Denis on July 07, 2024 at 11:29 AM
  This message has been viewed 345 times.
In Reply To Stumble stuttering when TT engine cold posted by AL on July 06, 2024 at 12:02 PM
Message First time was a bad throttle position sensor, NDSI (Consult knockoff) showed eradicate voltage readings when cold so the ECU thought I was flexing the throttle.
Second time was a cold solder connection in the fuel pump controller unit causing the pump to start and stop when cold. I found that via process of elimination. I was able to open the FPCU, find the bad joint and re-solder it.
If soldering electronics is not one of your skills Matt Lovett is a great electronics wiz supporting the members. (mattlovett@mattlovett.com)
