TwinTurbo.NET: Nissan 300ZX forum - Does your SPL kit include adjustable rear toe arms?
Subject Does your SPL kit include adjustable rear toe arms?
Posted by Polishzx on June 27, 2024 at 5:43 PM
  This message has been viewed 354 times.
In Reply To Rear end wobbly after hicas delete posted by Raposo224 on June 27, 2024 at 07:44 AM
Message I have the SPL kit that was brackets only, no arms. I thought I would use OEM Toe arms from an NA, but my rear toe was out of alignment with them installed, causing a similar issue you described. The SPL Brackets work great to delete HICAS, but I had to upgrade to some Powertrix Adjustible Rear Toe Arms to actually get rear toe in spec. Once in-spec, no more stability issues over bumps. If you do have adjustable rear toe arms that were recently aligned, I'd be curious what the rear toe spec says on results sheet.
