TwinTurbo.NET: Nissan 300ZX forum - Spooky under power?
Subject Spooky under power?
Posted by Doug71zt(CAN) on June 27, 2024 at 7:57 AM
  This message has been viewed 396 times.
In Reply To Rear end wobbly after hicas delete posted by Raposo224 on June 27, 2024 at 07:44 AM
Message Usually due to worn inner tie rod and/or HICAS ball joints.
Make sure to check them at ride height, sometimes they are tight when the suspension is unloaded on the hoist but have play at ride height.
If everything was correctly installed and aligned, you shouldn't have any issues with rear bump steer (toe change in relation to suspension travel)
Maybe a double check of the alignment is in order after a close look at the suspension.
